Hello, I need help clearing internal fault code for steering angle sensor.
Mechanical fault was repaired, but the fault does not clear.
95080 8K0953568G 8K0 953 568 G
Thank you!
Thank you!
tray this pass pm
BestElectrical (12th October, 2017), monter5555 (18th August, 2019), tekn95 (29th June, 2020), Tronics (9th November, 2021), VVDI (28th September, 2019)
can share password??
Wondering if anyone can help me. I have error with crash data i think but no adaptions work. I read by VVDi as there is no 95080 on board Can anyone assist me please with clear file.
i only see micro D70F3628
Thanks in advance
this eprom 95080
Sory this pcb different ,what year of production audi
ascotauto (15th May, 2018)
tray reflash sgo vas
antonypaul (19th July, 2023), ascotauto (15th May, 2018), nadirayyildiz (26th January, 2021)
will try and post results
do i change D flash or P flash? What must i write?
did you open this module
mine is not the same as your last picture
hi i have steering wheel audi a5 8k0953568F problem in the eeprom can you help me
hello please pass pm
Hello! help please, I need a memory dump 95080 of the 801053568g module of the rudder position sensor
