Page 1 of 10 123456 ... LastLast
Results 1 to 15 of 145
    BestElectrical's Avatar
    San Diego, CA, USA
    Default 2011 Audi S4 Steering angle sensor 8K0953568G internal fault
    Hello, I need help clearing internal fault code for steering angle sensor.
    Mechanical fault was repaired, but the fault does not clear.
    95080 8K0953568G 8K0 953 568 G
    Thank you!
    tray this pass pm
  3. The Following 5 Users Say Thank You to janusz21 For This Useful Post:
    BestElectrical (12th October, 2017), monter5555 (18th August, 2019), tekn95 (29th June, 2020), Tronics (9th November, 2021), VVDI (28th September, 2019)
    San Diego, CA, USA
    Quote Originally Posted by janusz21 View Post
    tray this pass pm
    Works! Thank you!
    Oct 2015
    can share password??
    Default Audi A4 8K0953568f Steering Angle Fault
    Wondering if anyone can help me. I have error with crash data i think but no adaptions work. I read by VVDi as there is no 95080 on board Can anyone assist me please with clear file.
    i only see micro D70F3628
    Thanks in advance
    this eprom 95080
    Sory this pcb different ,what year of production audi
  9. The Following User Says Thank You to janusz21 For This Useful Post:
    ascotauto (15th May, 2018)
  10. #8
    tray reflash sgo vas
  11. The Following 3 Users Say Thank You to janusz21 For This Useful Post:
    antonypaul (19th July, 2023), ascotauto (15th May, 2018), nadirayyildiz (26th January, 2021)
  12. #9
    will try and post results
  13. #10
    do i change D flash or P flash? What must i write?
  14. #11
    did you open this module
  15. #12
    mine is not the same as your last picture
  16. #13
    Aug 2014
    hi i have steering wheel audi a5 8k0953568F problem in the eeprom can you help me
  17. #14
    Jan 2018
    hello please pass pm
  18. #15
    Aug 2018
    Hello! help please, I need a memory dump 95080 of the 801053568g module of the rudder position sensor
