Results 1 to 5 of 5
    Default Edc15C DTC remove P1499
    Hi to all,
    Can someone please help me disable error code p1499 from this dump?
    http://www.digital-kaos.co.uk/forums/attachment.php?attachmentid=441752&d=1491677541
    Thanks,
    BR
    johak's Avatar
    for a test...
  3. The Following User Says Thank You to johak For This Useful Post:
    Hugolainz (20th October, 2017)
    Thanks a lot, error code is off.
    After programming IMMO light come ON, started first time an IMMO shut down the engine, removed key wait 30 sec, engine starts ok but lost all seat memories and key fob.
    Solved that.
    I have been for a long time trying to disable this code but lacked the logic to do it.
    Can you please explain your logic for disabling this code?
    I was looking just before the code 1499 HEX for the trigger and resume conditions, but you used a completely different logic.
    BR.
    johak's Avatar
    check out this
  6. The Following User Says Thank You to johak For This Useful Post:
    Quote Originally Posted by johak View Post
    check out this
    Again thanks, It seems I cant send you PM, so just so you know I understand it perfectly.
  8. The Following User Says Thank You to Hugolainz For This Useful Post:
    johak (20th October, 2017)
