here you go
Hi.
Need to do hot start and egr off. I modified intake manifiod by replacing egr by bypass kit, and getting P0401 - egr insufficienf flow.
If possible to make this good solution. Car is mine
ECU:
EDC16U1 | 0281012220
CAR:
GOLF PLUS 2005 1.9 TDI | BKC
If I help You. please say THANKS.
marek128 (16th October, 2017)
What were your symptoms with hot start fault
Johak i cant open the archive seem corrupted. (its OK my winrar was too old. sorry for mess)
Engine was taken apart and now is brand new. All parts get new as the connecting rod, piston, acetabulum. And when i make 10tys km i do big tunning. So when i wana start hot engine its take to long to start. Mechanical is better than brand new.
Here my solution od hot start but dont know its good. I copy cold start map to hot start by ECM Titanium. How U think it will be ok?
Is starter motor ok sometimes when hot cranking is too slow!!!!
No its so fast than you can run on him and be faster than Bugatti Chiron
teerak2uk (16th October, 2017)
hot start fix+ egr hysteris edit. delete fault via diagnostic and it should not appear again.
