Results 1 to 4 of 4
    Oct 2017
    Default Itīs posible IPTV in DM 500C?
    Iīm Reading but iīm not understand well. Is it posible to install any firmware with IPTV in DM 500C?
    I read like is not posible, because IPTV only Works in Enigma II.
    but in the DM500 images secction are one post about OpenPLi 4.0 IPTV v20 by MastaG with IPTV (1300+ FREE IPTV Channels) for Japhar NC3 Su. That Works?
    digicon's Avatar
    That image is for a DM500HD which is Enigma2 you have an Enigma1 device
  3. The Following User Says Thank You to digicon For This Useful Post:
    osobuque1 (18th October, 2017)
    Oct 2017
    So there arenīt enigma 1 firms for IPTV.
    toysoft's Avatar
    Nov 2008
    To explain you, the DM500S/C/T Boxes are MPEG2, and all IPTV is at least H264/MPEG4, and this is only supported in the boxes that support HD (High Definition)... as well as the CPU is really not enough powerful for watching IPTV, you need at least DM800HDpvr at 300 Mhz Single Core, but better is DM800HDse/DM500HD with 400 Mhz CPU Dual Code.
    Hope this clarify your ideas,
    TS
  6. The Following User Says Thank You to toysoft For This Useful Post:
    osobuque1 (24th October, 2017)
