Hi!
I do have made amilage in BMW e60 330d but have damaged the cluster and have bought new one, with the same part number:62.11-6 983 153
same SW number: 59.51.0
Same as oryginal but when I put it on in dash I get yellow car and message in car: "level control system failure".
When I take out the dashboard, then there is no such failure in iDrive....
When I connect the oryginal one, there is also no such failure neither on dash nor in iDrive...\
So the failure comes up when the new dash is connected.
How to adapt the new dash to vehicle?
This BMW e60 does not have pneumatic suspension and i suppose that cluster is from model with pneumatic suspension.
what should i copy from oryginal cluster to new to adapt it? Or what should I do?
Oryginal cluster that works but left turn signal still flash
New cluster that shows "level system failure":
When I connect ISTA then it does not show any failure connected with level/supsension system i thing it bad adaptation/version of ne cluster.
Should I copy Eeprom? and reset CAS odometer to 0km? that will solve the small yellow triangle on odometer but will it solve "level system failure?
How to adapt new cluster? Kombi reprograming? Swaping all EEproms and flash from org to new?
Waiting for respone,
Kuba
