Results 1 to 3 of 3
    jodge's Avatar
    Mar 2017
    Default Disabling tire pressure sensor
    2005 Opel/Vauxhall Corsa
    Can i disable the tire pressure sensor warnings or the whole sensor like the immo from ecu? Or can i cheat the middle value with a resistor or something? Unfortunately i don't know the sensor at all
    The main problem is the spring/autum period in my country when the themperature fluctuation is too high and the sensor going crazy
    thx
    jodge's Avatar
    Mar 2017
    it seems it's more complicated to apply a simple resitor trick
    https://m.eet.com/media/1041632/DC_UTH_1533_pg26.gif
    Spain
    M8, just try to code as no pressure tyre sensor installed using opcom.
    Regards.
