Hi again people, i did again a Mazda 6 of 2006 this time, and again this MT401 surprised me, 30 seconds job, works perfekt
Hi again, as nobody began to share its feedback for this tool , i try this to a Mazda 3 of 2005 , and i was surprized , this tool did this car like a charm, and for the mazda cars it has an autodetect function, and allows you to create a backup, save it, and if something goes wrong you can allways backup from its menu, and it is all obd port function, if some one need the original supplier address i will help you, just PM me, bye
Wow! Tell us something new? Maybe golf 7 By OBD. Mazda can be corrected eith a $50 cable
Sent from my SM-G950F using Tapatalk
brend (12th April, 2020)
yes my friend, this tool can do golf 7 too
Today i was surprised , i try this tool at mercedes B class or 2006, and i was shocked, the tool did all itself in a press of a button, as i was on both cluter and tool during the process , after i press the new km, first the cluster changed itself to 999999 which mean it block the ezs sync with cluster, than changed back to the new km what i write, i never thought this tool can do all this, 1 hour of working with removing ezs and cluster, after that had to wire up and programm , with this tool is no more than 20 seconds job, so one more time a big thank to obdprog
Merdedes B Class W245 km fix through obd is OK
i know that ezs will block at 1,6 milion km my friend, i,m not new, but you should know that even when you do it with direct programming with tools such as R270 or other ways, you do the same, you are not able to write the same km at ezs and cluster too
next time i will post a video for sure my friend, today i was scarryed by my self too, cause i didn,t know what could hepened to the zgw module or ezs too, but i,m going to trust more and more this tool, i have a lot of tools, but this is a surprise
Looks like the x300 is twice the price but both have big gaps. The Android interface would be a plus in the X300 column. Neither unit have much for real world reviews.
hcip (22nd October, 2017)
Did someone test this on golf7 ?
in its menu it is, but I'm afraid to use it in that car vw golf7
Vw amarok ok mileage .. 2010 -2014
https://youtu.be/4pcc7Yh53Cg
WINNER THE LOSER
