AUDI A4 2.0 TDI BRD 125KW PPD1.3 03G906018AQ DPF, EGR OFF
Results 1 to 4 of 4
    Oct 2017
    Downloads
    Uploads
    Default AUDI A4 2.0 TDI BRD 125KW PPD1.3 03G906018AQ DPF, EGR OFF
    Hello friends,
    I need help with my Audi A4 2006 2.0TDI BRD 125KW 03G906018AQ, PPD1.3
    Car are in workshop for 4 weeks (No power after 3k(no boost), smoke from exhaust like to much fuel, bad starting, bad work on idle.):
    Turbo -> OK
    Injector were removed and checked->OK
    Tandem and Fuel Pumps->OK
    Everything Checked, even tried to change ecu. The same.
    I have opinion maybe its DPF or EGR-> Worth a try, but i don`t have any error is VCDS.
    Maybe somebody can help me with DPF-off and Egr-off and any unnecessary problematic stuff off.
    File read through OBD port.
    Thanks in advance.
    DK Veteran mariazo84's Avatar
    64
    Downloads
    189
    Uploads
    Goodnight
    I have had the same problems in several a6 blb also have small jerks?
    check the screws and toricas of the inectors in my case several were stretched.
    Oct 2017
    Downloads
    Uploads
    New screws fitted after injectors was checked. On stationary tester. :/
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    576
    Downloads
    Uploads
    Quote Originally Posted by HydrogenV12 View Post
    DPF + EGR off.
    Pass PM, use THANKS and REP button (star)
    let your tool make chks.
    [SIGPIC][/SIGPIC]
    DSG TUNING
    File Service
    Autotuner - Genuine
    Kess 5.017 EU, Galletto v54 EU, Ktag 7.012 EU - Clones
  5. The Following User Says Thank You to maajkii For This Useful Post:
    HydrogenV12 (19th October, 2017)
