Results 1 to 13 of 13
    raimi.s's Avatar
    Garage
    Default ford galaxy im*o
    i have galaxy 2.3l 1999. need remove im*o.but i don,t now or is posible and how?
    Slovakia
    Read pin code from immo and program new keys this ist the best way.
    Or explain why you need to immo off.
    You must give number of ecu if you want answer.
    But I think erikfrog have right.
    raimi.s's Avatar
    Garage
    one men bring this car for me two days ago, and was all wires cuts from immo box , and don't was ECU inside,so i get new ECU and now i want start this car faster. Ecu number is JACK XM2F-12A650-EA
    Clifton ENGLAND
    Default ecu / ecm pic required
    i have same im*o no INKS XM2F-12A650-DA EEC-V
    1999-2000 YEAR 2.3 petrol
    ford galaxy
    can clear dowm im*o correctly but will not accept keys have tried for 3 hrs and others have tried over 3 weeks
    curently no keys programmed
    code 1000 set ( will be clear now as ecm been off for two days
    does any one know which chip to read on this ecm
    and can tell me what to read so i can post for im*o off
    Sweden
    i have same type of problem, did you resolve it?
    obdmaster's Avatar
    Never never land
    Question
    I had one of these with immo problem and key wouldnt program. In the end it was because of engine control relay in fascia fusebox, replaced relay, then keys would program.
    autodiagservices's Avatar
    Quote Originally Posted by obdmaster View Post
    hello obdmaster,
    i have a Ford Galaxy Immobox part#: 7M0 953 257 L or S, whenever i tried to program key using SBB, it will accept the key in the ignition as #1 key but will failed to accept the key #2 after i switch off and on as instructed,
    pls i need immo off for ECU part#: 98VW-12A650-EA if possible.
    regards
    koncimobil's Avatar
    Sep 2011
    soxxi
    Immo off galaxy .....?????
    Ahaaaaaa......
    Like dreaming....
    Quote Originally Posted by koncimobil View Post
    Ahaaaaaa......
    Like dreaming....
    hello koncimobil,
    do you have any idea about any known solution? pls help.
    regards
    vanos batam's Avatar
    Batam-Indonesia
    Quote Originally Posted by autodiagservices View Post
    hello koncimobil,
    regards
    found immo dump..
    pls post
    Quote Originally Posted by vanos batam View Post
    found immo dump..
    pls post
    hello vanos,
    do you have any idea where the immo dump is located?
  13. #13
    alclot's Avatar
    Melee Island
    Hi mates! I?m triying to find immo chip in ecm for match key but I dont find it. Does anybody know where is it?
    Thanks in advance
