Results 1 to 11 of 11
    Oct 2017
    Default help for damos or map address
    Hi to everyone
    finally i have read the ecu in bootmode , but i cannot find the correct damos for winols and i don't found the right map to tune can anyone help me for tuning or for find damos ?
    The ecu is 0261201917 1037389477 1.8 tsi bzb i attach the file
    Jul 2017
    What car and year is this?
    Sometimes if you donīt have the right mappack, do you need to find some map of closer ECU, and find the maps one by one,
    is a lot of work, but if you donīt have the right mappack its a solution.
    I have some mappacks, but I need know what ECU is this, Bosch MED17.?.?
    Oct 2017
    It's a seat leon 1p 2008 1.8 tsi bzb and the ecu is a med 17.5
    i found it is attached for everyone need them
  4. The Following 3 Users Say Thank You to antonino8666 For This Useful Post:
    nikosp11 (20th February, 2023)
    Jul 2017
    Thumbs up great
    yes, this a2l works great for your file
    Nov 2017
    netherlands
    Hello
    i have also a 1.8tsi bzb engine and it is tuned.
    210ps
    Oct 2017
    Quote Originally Posted by vinsk8 View Post
    Yes but i think that the map of ignition kfzwop have a bad address , i see strange value can anyone tell to me the right address or confirm that the value are correct ?
    Feb 2014
    Spain
    I think kfziop starts at 524F2.
    There is a similar problem with KFZW also.
    Andrei2015's Avatar
    Oct 2015
    Quote Originally Posted by antonino8666 View Post
    KFZWOP can find it at 524F7, there are 4 maps, factor 0.75, 8bit maps
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
  10. #9
    Oct 2017
    Quote Originally Posted by Andrei2015 View Post
    Quote Originally Posted by biela View Post
    Can you indicate to me the right address of KFZW please ?
  11. #10
    Andrei2015's Avatar
    Oct 2015
    KFZW - 51592
    KFZW2- 51652
    KFZWLB1-51712
    KFZWLB2-517D2
    X-axis - engine speed - 5056E - 16bit LoHi factor 0.25
    Y-axis - Relative Air charge (Word) - 16bi LoHi factor 0.0234375
  12. The Following 2 Users Say Thank You to Andrei2015 For This Useful Post:
    antonino8666 (16th November, 2017), pautri (14th November, 2017)
  13. #11
    Aug 2021
    thank for file
