Results 1 to 9 of 9
    Dec 2012
    uk
    Default bmw x5 key problem
    Hello. I have problem with bmw x5 e53. Car was discharged battery and don't crank. EWS have fault "wrong changing code, key1". I was prepared new transponder pcf7935 and now i have fault "wrong changing code, key 3". I was change ews, but still don't work.
    Live data show "wrong random code"
    where is problem?
    ews hw03 0d46j org.rar
    brend's Avatar
    Oct 2015
    Same where
    What tool you use for this?
    Dec 2012
    uk
    for ews i use xprog, for diagnose pasoft 1.40
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by nynol View Post
    for key prepare what tool?
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  6. The Following User Says Thank You to kiszka For This Useful Post:
    nynol (21st October, 2017)
    electrones's Avatar
    Feb 2012
    Around C.V
    To prepare key EFfi and zedbul is good pcf7935 job done, if not work u need sync EWS with ECU
    Cheers
    Press "THANKS" button. just one click, CHEERS
    Dec 2012
    uk
    for prepare I use effi zedbull, i try sync dde - ews and dont work
    Dec 2012
    uk
    problem solved. thank You kiszka
  10. #9
    May 2009
    Madagascar/Antananarivo
    Can you explain to me how you did to solve your problem?
    you have exceeded your stored private messages quota and cannot accept further messages until you clear some space.
    Thanks,
