Results 1 to 8 of 8
    Aug 2015
    Default Please Help Audi a4 2007 ecu map
    Hello, can someone please check map from this audi if it is ori or not?
    Problem is car dont have power (low injection quantity) at lower RPM untill it reached about 3000rpm when is going good. Mechanic changed and checked everything, injectors are new etc.... Now they suspect ecu map, can someone please check if map is ori? thanks
    kess id:
    HW:
    SW: 1037391501
    VIN nr.: WAUZZZ8E07A220824
    SW ver.:
    Spare:
    Engine: R4 2,0L EDC
    HW Ver.:
    SW upg.: 03G906016KM 9896
    Installation:
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    file isn't ori, but i cant find ori in web...
    DSG TUNING
    File Service
  3. The Following User Says Thank You to maajkii For This Useful Post:
    dtip (21st October, 2017)
    Aug 2015
    tnx mate, what do you think can it be problem of low power?
    can i flash this file (map only) ? http://www.digital-kaos.co.uk/forums...3G906016KM-bdm
    maajkii's Avatar
    Mar 2017
    yes you can but via BDM
    DSG TUNING
    File Service
    Aug 2015
    of course bdm, thanks for your help, can you tell what is wrong or what is dont on map?
    maajkii's Avatar
    Mar 2017
    I dont check it mate, im just shure its not ori.
    Im out of home now
    DSG TUNING
    File Service
  8. The Following User Says Thank You to maajkii For This Useful Post:
  9. #7
    Aug 2015
    Quote Originally Posted by maajkii View Post
    Im out of home now
    i understand, tnx, any other tuner can maybe check if this map is f**ked up? and what is wront with it?
  10. #8
    sida's Avatar
    May 2014
    System32
    This file is 100% ori.
  11. The Following User Says Thank You to sida For This Useful Post:
