Results 1 to 8 of 8
    gejzaslapka's Avatar
    somewhere over the rainbow
    Default Audi A4 EDC16 2.0 TDI BPW engine - Disable EGR+error code
    Hello, can someone please disable EGR+ error code to work withouit trouble code with disconnected egr valve
    Many thanks in advance
    GS
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    your file with egr off calculate checksum before write
  3. The Following User Says Thank You to AVDigitale For This Useful Post:
    gejzaslapka (24th October, 2017)
    johak's Avatar
    if I missed the dtc post P code here
    thank You very much, Here is full bdm for sure........it is tuned and without dpf already...
    is disabled that error code?
    P0407 as in attached log from VCDS
    johak's Avatar
    p407 has been deleted
    johak's Avatar
    your bdm file
  9. The Following User Says Thank You to johak For This Useful Post:
  10. #8
    Thank You both very much
    GS
