Results 1 to 10 of 10
    leandroks's Avatar
    Brazil
    Default Jetta Tiguan Keyless go
    Hi there, does any one who have already programmed VW tiguan or Jetta Keyless go key?
    I am trying to do so and no matter what i try the remote wont work, transponder has been successfully programmend and car starts ok as long as i put the key on the collumm place, but the proximity and remote lock is no work.
    The question is, when i program the transponder the remote shoud be programmed as well or do i need to perform a " remote programming"??
    Thanks in advance.
    BR
    Leo
    leandroks's Avatar
    Brazil
    Anyone could help???
    Maartinj's Avatar
    Nov 2010
    me
    You need for example VVDI2 to add proper Kessy key
    and not add key directly to cluster, because it will only work as emergency key
    you need do key Learn via IMMO data , and on the end - VVDI2 ask you " is a regular key or Kessy key"
    choice Kessy key and key is adapted.
    if you add key into cluster now and you have VVDi2 , you need re-learn all keys
    of course Key must be a proxy key , not a regular ID48
    Iscan Car MM-007 can also do this ...made by Xhorse too
  4. The Following 3 Users Say Thank You to Maartinj For This Useful Post:
    clauberty (30th June, 2020), Jobeso66 (19th May, 2019), leandroks (25th October, 2017)
    leandroks's Avatar
    Brazil
    I ve got avdi, my vvdi didnt arrive yet, my key is kessy, would vas do it???
    Thanks..
    Maartinj's Avatar
    Nov 2010
    VAS too, but online
    with VAS you need to know which KEy is nr 1 , nr 2 etc
    and to re-leran key you need to start from 1 , and go to next
  7. The Following User Says Thank You to Maartinj For This Useful Post:
  8. #6
    Jan 2016
    VAS online will only learn original key that came from VW FAZIT baze. Aftermarket keys: VVDI2, AVDI. But where to get aftermarket Keyless keys for this ones ??
  9. The Following User Says Thank You to amigokola For This Useful Post:
    yugo45 (28th October, 2017)
  10. #7
    leandroks's Avatar
    Brazil
    autokeys are selling those kessy keys. If works i dont know but they got it;..
  11. #8
    ThiagoArgentino's Avatar
    May 2016
    Brazil
    Quote Originally Posted by leandroks View Post
    Did you manage to solve Tiguan, mate?
    Solutions in the area of automotive coded keys, all automakers.
  12. #9
    leandroks's Avatar
    Brazil
    I am waiting for may new vvdi2 full and give a try... I ll let u know as soon as i got over that;;
  13. #10
    Maartinj's Avatar
    Nov 2010
    did kessy key many times, no problem with VVDi2 , also MM-007 IscanCar can do it too
  14. The Following 2 Users Say Thank You to Maartinj For This Useful Post:
