Results 1 to 13 of 13
    Aug 2013
    uk
    Default Mercedes atego key logic
    i have atgeo 906 mr unit.
    i read 93c86 x16
    Could someone give me good key logic please.
    I had
    FF 81 04 8F 02 65 4A 6F - NOT WORK
    FF 81 DC 8C 02 8A 95 09 - NOT WORK
    any help would be great. thank you.
    If i helped.... please dont forget to press the THANKS + REP buttons .
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Key 1 ID : 2004CAA9
    Key 2 ID : 20046AD5
    Key 3 ID : 2004846A
    Key 4 ID : 2004B973
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  3. The Following User Says Thank You to CarCity For This Useful Post:
    thayer201 (25th October, 2017)
    Aug 2013
    uk
    Quote Originally Posted by carcity View Post
    Key 1 ID : 2004CAA9
    Key 2 ID : 20046AD5
    Key 3 ID : 2004846A
    Key 4 ID : 2004B973
    need key logic to write to T5 ?
    doctore's Avatar
    Nov 2015
    Colorado Denver
    write t5 glass FF 81 A4 40 B1 A4 C0 63
    and start the truck
    or this FF 81 04 80 02 C5 92 1A
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  6. The Following User Says Thank You to doctore For This Useful Post:
    Aug 2013
    uk
    Quote Originally Posted by doctore View Post
    write t5 glass FF 01 A4 40 B1 A4 C0 63
    and start the truck
    Is that 81 instead of 01 ?
  8. #6
    doctore's Avatar
    Nov 2015
    Colorado Denver
    ........yes sir
  9. The Following User Says Thank You to doctore For This Useful Post:
  10. #7
    Aug 2013
    uk
    FF 81 04 80 02 C5 92 1A - NOT WORK
    will try the other one.
    br
    and start the truck
  11. #8
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Did you turn on that hell of a machine?
  12. The Following User Says Thank You to doctore For This Useful Post:
  13. #9
    Aug 2013
    uk
    Not yet..... all other key id not work will try your first one and let you know.
    thanks for your help.
  14. #10
    Aug 2013
    uk
    if this doesnt work does anyone have working flash + eep dump for euro 3 906 unit possible 1225 or higher..
    has flash 29f200 and 93c86 eep
    If anyone has a working set please share.
    A062 446 06 40 ZGS 001
    OM906 III/2-00
    Quote Originally Posted by thayer201 View Post
  15. #11
    Aug 2013
    uk
    update - tryed other key data - not working.. found issue with mis match data on unit so write new data and truck start..
    So think key logic was correct for dump but not a matching set with flash...
    thanks again for your help.
  16. #12
    lion0304's Avatar
    Oct 2014
    WHen you write T5 with data, do you select iD13???
  17. The Following User Says Thank You to lion0304 For This Useful Post:
    thayer201 (27th October, 2017)
  18. #13
    Aug 2013
    uk
    yes i did select ID13 - problem was eeprom contect had been changed before came to me - made keys no luck tryed them all... so had working flash and eep from working truck and used that and coded keys truck started...
    I belive the key data was correct for that dump but still had issues with it geting it to work
    problem solved... thanks anyway
    Quote Originally Posted by lion0304 View Post
  19. The Following User Says Thank You to thayer201 For This Useful Post:
    lion0304 (28th October, 2017)
