Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 51
Hybrid View
    Oct 2017
    Perfect but i have problem with my VCI DEVICE she is seen but read as unknown the "ACTIA" driver is istalled so how can i flash it or make it work ?
    Thanks for your work bro !
    Jul 2017
    You need to install drivers for VCI from the drivers folder (Device manager)
    Jul 2017
    If after installation the problem occurs, the VCI is not recognized or only partially...check
    1. PC cable not properly connected to the tester.
    2. Power cable is not connected to tester
    3. Incorrect Com Port selected
    1. lookup whether the inserted VCI VCI has been recognized under a Comport - yes - com port select, if not please reinstall drivers. (Control Panel)
    2. OBD connector from VCi not connected to the vehicle, no power supply 12V for VCI.
    3. Wrong ID at the beginning of the installation: for example. for CDP rather than A-710-479 was a CDP-710-142 for CDP + then input comes the mistake is not recognized.
    4. Incorrect serial number for the VCI. Change the VCI serial and HW Key in the installations.xlm make new activation and VCI run fine.
    5. USB cable is defective, broken, or cross-section of cable too small, take thicker USB cable.
    6. Firmware broken: re-record with Flash loader demonstrator.
    7. VCI has polluted or cold solder joints, take the VCI apart and solder / clean.
    Message "Communication Error vehicle is not responding"
    USB jack soldered incorrectly. 12V not okay. If the VCI has 2 boards then they are not put together correctly..check.
    Message: "Unknown Serial Number Please check whether the installed version for their VCI-type is valid"
    Incorrect Main.exe copied / installed, patch "Main.exe" copy back into the installation directory
    Important for Windows 64-bit versions:
    If you have a 64 bit Windows system on the computer then you have after installing the Delphi folder or Autocom in the following directory copying: C: / Program Files (x86) then the program will run without any problems. If this is not done has to when every time you start over again the first configuration screen.
    If the Delphi / Autocom folder in the directory C: / Program Files (x86) has been moved then just a new shortcut on the desktop to create and launch.
    After installing the error comes:
    "Installation of product ducuments failed! The installation will quit"
    "dotnetfx 4.0" installed ... With this version definitely takes the above-mentioned error during installation.
    "dotnetfx3.5" install and the installation is running.
    If I helped you do not forget to thank and reputation :-)
  4. The Following 2 Users Say Thank You to Pietrek For This Useful Post:
    kikecha (13th January, 2018), rankan (22nd September, 2020)
    Feb 2015
    Germany
    Windows 7 32bit reinstalled, your version installed and activated, OBD does not work, only Generic OBD works, license has 5 limitations !!!!! Can you unlock more in my file?
    FileActivation.zip
    Jul 2017
    Quote Originally Posted by kotnascher View Post
    FileActivation.zip
    What to install? Delphi / Autocom?
    Cars / Trucks? what serial number? 100251?
    I can still activate dieselmax and turbocharger.
    Feb 2015
    Germany
    Delphi CARS 100251, very good wenn you can
  8. The Following 2 Users Say Thank You to kotnascher For This Useful Post:
    alexbravo (4th May, 2019), hidra (9th November, 2019)
  9. #7
    Jan 2018
    Many thank's for this :-D Please activate ? Attached is activation file :-)
  10. #8
    Jul 2017
    Quote Originally Posted by bvmhs View Post
    http://www.digital-kaos.co.uk/forums...=1#post3167779
  11. #9
    Jun 2023
    Hello! new to all of this
    I can`t activate delphi 2014.3
    100251
    EGDFZJFAVQED.
    Do I need a new activation from you? or am I just instaling it wrong? I keep getting "operation failed" after opening the generated activation. Could you help? Thx in advance!
  12. #10
    Aug 2020
    Quote Originally Posted by iuliatat View Post
    100251
    EGDFZJFAVQED.
    You can find 2020.23 and the fake c4b 2021 or the 2022.02a from us instead of this old version
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  13. #11
    Jul 2017
    PW
    Do not forget to thank and press your reputation :-)
  14. The Following 2 Users Say Thank You to Pietrek For This Useful Post:
    bvmhs (11th January, 2018), hipeka (29th November, 2017)
  15. #12
    Can you Pietrek help me with this file activation?
  16. The Following User Says Thank You to hipeka For This Useful Post:
  17. #13
    Jul 2017
    Quote Originally Posted by hipeka View Post
  18. #14
    Delphi Cars
    DS150E
    Serial 100251
    Hardware key EGDFZJFAVQED
  19. #15
    Jul 2017
    Delphi Cars
    DS150E
    Serial 100251
  20. The Following 2 Users Say Thank You to Pietrek For This Useful Post:
    hipeka (5th December, 2017), Matheas (12th February, 2020)
