Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
Hybrid View
    Jul 2017
    Default Activation Autocom Delphi 2014 Release 3- no hex2stuff
    If you already have the version of Autocom / Delphi on your computer, we must first remove it entirely, otherwise the installation will not work properly .......
    Follow these instructions:
    Delete the following folder:
    Windows XP
    C: \ Programs \ Autocom
    C: \ Programs \ Delphi
    C: \ Documents and Settings \ All Users \ Application Data \ Autocom
    C: \ Documents and Settings \ All Users \ Application Data \ Delphi
    C: \ Documents and Settings \ ** USER * * \ Application Data \ Autocom
    C: \ Documents and Settings \ ** USER ** \ Application Data \ Delphi
    C: \ Documents and Settings \ ** USER ** \ Application Data \ Microsoft \ SystemCertificates \ My
    C: \ Documents and Settings \ Microsoft \ SystemCertificates \ My
    C: \ Documents and Settings \ LocalService \ Application Data \ Microsoft \ SystemCertificates \ My Documents
    C: \ Documents and Settings \ NetworkService \ Application Data \ Microsoft \ SystemCertificates \ My Programs
    Windows 7 and 8:
    C: \ Programs x86 \ Autocom
    C: \ Programs x86 \ Delphi
    C: \ users \ ** USER ** \ AppData \ Roaming \ Delphi
    C: \ users \ ** USER ** \ AppData \ Roaming \ Autocom
    C: \ users \ ** USER ** \ AppData \ Roaming \ Microsoft \ SystemCertificates \ My Other
    AXIS:
    similar folders.
    Edit scrapbook:
    C: \ WINDOWS \ system32 \ drivers \ etc \ hosts
    und Lösche:
    127.0.0.1 activation.autocom.se
    127.0.0.1 activation2.autocom.se
    127.0.0.1 updates.autocom.se
    Run remove the certificate
    Start CCleaner and delete the registry
    Restart your computer
    Install a new version
    To prevent updates online: Rename this file
    "wyUpdate.exe" according to "wyUpdate.bak" or "wyUpdate1.exe"
    Thank you and your reputation when I help you
  2. The Following 6 Users Say Thank You to Pietrek For This Useful Post:
    dadal (16th January, 2018), hipeka (29th November, 2017), nos_com71 (23rd December, 2018), rankan (22nd September, 2020), rtbdiagnostic (24th July, 2019), Tohelo101 (6th December, 2017)
  3. #2
    Jul 2017
  4. The Following 6 Users Say Thank You to Pietrek For This Useful Post:
    hipeka (29th November, 2017), iuliatat (5th June, 2023), joejam (8th December, 2021), lynxman (7th January, 2018), MARIKO (10th February, 2021), Papiti56 (2nd December, 2017)
  5. #3
    Jan 2016
    I have downloaded :
    1- 2014.3 Autocom Cars/ Tracks and
    2- 2014.3.2 final
    when I click on main exe in first download ( number 1 ) it shows by start up "hex2stuff version " ( titel of this topic says No hex2stuff )
    I dont want to instal hex2stuff version,,so then need I to instal second download ( 2014.3.2 final ) ???
    you say :
    Important for Windows 64-bit versions:If you have a 64 bit Windows system on the computer then you have after installing the Delphi folder or Autocom in the following directory copying: C: / Program Files (x86) then the program will run without any problems.
    there is no instal exe which one does create automaticly a folder in C: / Program Files (x86) ,,,need I to self create that folder ? ( C: / Program Files (x86) ) and all files to copying/move in to this folder ?
  6. #4
    Dec 2014
    PL
    Quote Originally Posted by mrchip View Post
    I have downloaded :
    2- 2014.3.2 final
    you say :
    Hi.
    Everything what you need. Post No. 172.
    http://www.digital-kaos.co.uk/forums...autocom+delphi
  7. #5
    Feb 2018
    paris
    Why McAfee detected the virus when trying to get the PATCH ?
    thank
  8. #6
    Jul 2018
    Default can you activeit licence please
    can you activate
  9. #7
    Dec 2014
    PL
    dainix1990
    Try and report. (2014.3)
  10. #8
    Jul 2017
    Patch
    https://mega.nz/#!iZAT3QRa
    !8BXv6VhBpYInRt3ER5w3yZSauVyEBsj_eLyZuQMgGdk
  11. The Following User Says Thank You to Pietrek For This Useful Post:
  12. #9
    Oct 2017
    Default Thans you !
    [QUOTE = Pietrek; 3129304] https://mega.nz/#!iZAT3QRa ! 8BXv6VhBpYInRt3ER5w3yZSauVyEBsj_eLyZuQMgGdk [/ QUOTE]
    Thank's dude !
    I'm downloading 2.8GO software can u keep me in touch for activation ?
    Best regards,
    Fabien
  13. #10
    Jul 2017
    Quote Originally Posted by LoveKaos View Post
    Thank's dude !
    Best regards,
    Fabien
    Yes :-) Activate, paste here your FileActiwation zip / rar.
  14. The Following User Says Thank You to Pietrek For This Useful Post:
    LoveKaos (25th October, 2017)
  15. #11
    Oct 2017
    No problem i'll do it once it's finish.
    Is it important to have Autocom or just Delphi should i download both versions ?
    Doest windows versions (10 x64bits) works with ?
    Thanks for your answer
  16. #12
    Jul 2017
    You have the choice of Autocom / Delphi / Cars / Tracks or a special version where everything is :-)
    Good luck
  17. The Following User Says Thank You to Pietrek For This Useful Post:
  18. #13
    May 2024
    Default Help i need activation...
  19. #14
    Oct 2017
    Smile
    Finally installed on my tablet diag computer VirtualBox (7 PRO SP1 x32bits) !!
    NOW i'am near to enjoy your superb modified DELPHI
    I join you the FileActivation.xml
    Thanks for your work
    PS: For other users don't forget to change patch even if it's version "R3.2" ENJOY !
  20. The Following User Says Thank You to LoveKaos For This Useful Post:
    Pezhoo (1st October, 2023)
  21. #15
    Jul 2017
    Default LoveKaos
    Your activation
    If I helped you give thanks and reputation :-)
  22. The Following 8 Users Say Thank You to Pietrek For This Useful Post:
    barski007 (20th December, 2020), Charl33 (22nd January, 2024), dragan1201 (4th January, 2019), LoveKaos (26th October, 2017), Pezhoo (1st October, 2023), sam1987 (2nd December, 2018), ziptirik (23rd February, 2019)
