There was a flaw in the orginal script for picking up the EPG data and dumping it to specific location on the box. This was later fixed so I have amended the instructions and removed the manual copying of the file to the correct location.
1st you need hdd installed to store epg data!!
2nd your box connected to the internet !! (doesn?t have to b all the time, just for downloading epg data etc..)
3rd setup your bouquets favourites etc?(prob have done this already)
Ok set epg to SQLite EPG database go to system settings either (menu, setup, system settings, EPG) or (blue button, dreambox settings, system settings, EPG)
In EPG
Set epg data store: to SQLite database
Set epg location: to Internal harddisk
Epg directory should say /media/hdd
Set epg days to 7 (just example u can change 2 whatever latter)
Press green button to save.
Exit
now go to downloads (blue button, software management, downloads, addons/plugins, SQLite EPG grabber EPG plugin.
check the download is ok ? (yellow button, plugins, dreambox epg config).
in the config.. package will probably say Digital+ and when dropped down Wolf_nl, & possibly Radio Times as well? we?ll come back to this
Now in tv mode select your Bouquet you want times epg 4
Select a channel (any one as long as your in the bouquet)
Now back to dreambox epg config (yellow button, plugins, dreambox epg config)
in the config.. package it should only say Radiotimes UK now as you got rid of the other crap ha ha
set time offset to 0 hours
number day 7
Cron options
Check use cron if you want your box to automatically get epg at time 6:00 (can set it 2 whatever time u want)
Press green button channels:-
On the left side you should have the radiotimes channel list, on the right your bouquet channels.
From the left scroll down to ie? bbc 1 select ? highlite will b a box now & on the right the highlite will appear at the top scroll down to match it with you bouquet channel
Continue till you have matched all your channels.
Then press green done. Exit
Back in epg config press yellow retrieve:-
Wait for the retrieving to finish press blue done. And exit menu back to tv
