Hi to all!
Can somebody tell is is good or bad egr and dpf off on this file?
If is good pleaee help with cecksum.
Thanks!
ECU info:
HW: CAYC
SW: 03L906023GL
SW upg.: 03L906023GL 5810
Installation: 1,6l R4 CR td
Hi to all!
Thanks!
ECU info:
HW: CAYC
SW: 03L906023GL
dpf+egr+speedlimiter no chks.. what tool you use? kess and v54 correct chks in writing
Jashmine1983 (26th October, 2017)
Here is your file... In arch is working soluion and your with corredct chk.
pass in pm..
ads 2017 works on this ecu
ecuworks (9th November, 2018), Jashmine1983 (29th October, 2017)
Can somebody tell if the file from first post is good or not?
Understood...can somebody help with a good solution?
eculevelsolution worked good after SHOOT reset.Ads 2017 not works on this ecu. The fuel pump is not activated on car. Used the ads 2017 egr solution, then DPF solution, not the one with both on same time.
eculevel (31st October, 2017)
Please share the stock on this car
I can make it best DPF/EGR/LSU off total. EGR unplug, also sensors. contact PM if need
Alientech KESS + KTAG, MagPro2 X17, FLEX Flasher, AVDI by Abrites, WinOLS Genuine Full, Maha LPS3000 Dyno machine.
