Results 1 to 7 of 7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default Med17.7.3 dtc off
    Hello , i need help with this ecu. Car is Mb e w212 (facelift). I need delete one dtc ( prem air sensor ( USA VARIANT) fault code is P2571
    Regards, thanks and reputation in advance
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Nobody???
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Or maybe someone can use some soft solution, which deletes some foults, so i would take a look if my dtc solutions are good for this ecu..
    johak's Avatar
    try this....
  5. The Following User Says Thank You to johak For This Useful Post:
    Ignasvw (27th October, 2017)
    johak's Avatar
    check out this
    Feb 2017
    hello neepd pass to Attached Files
    Sep 2015
    Dear you can decode it by a scanner. Just coded by autel maxisys.
    تم الإرسال من HMA-L29 باستخدام Tapatalk
