Results 1 to 5 of 5
    Sep 2017
    Default 2017 Ram promaster pin code
    Working on my promaster , I found out something.
    All lost key situation , it not necessary to extract pin code from OBDii, you can get it after you get your cuts on the cylinder , reverse it to key cut digit number and that is your pin code for programming ,
    p1et's Avatar
    Oct 2013
    I don't understand correctly this. Can you explain more pls? How can I reverse cuts to cuts? You mean numbers stamped on door lock/ignition? And what next?
    Do you use the key code or wafer numbers?
    ray-ray's Avatar
    There is 2 pin codes for new Chrysler/fiat (4digit rolling code) and a (5digit fix code)
    key has 8cuts how do you figure 8 into 5 or 4
    Jan 2017
    USA ����
    hes saying get the cuts from the cylinder and reverse it into a key code
    like going from chevrolet cuts 4342213532
    and going backwards and finding the key code which is g1234
