Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
  1. #31
    Oct 2015
    Ciaofriend what have new for problem rneg
    sucure pin 5rx
    pin 5 tx
    pin 1 gnd
    what have photo
  2. #32
    Aug 2019
    Hello
    I have a problem for 1 minute and it turns off at the desk!
    Any solution?
  3. #33
    Oct 2015
    Default rneg reanemate
    [QUOTE = talel66; 3535192] ho martech box 3, mi collego con rneg ma ho questo problema
    quando clicco all'avvio di emergenza ho questo messaggio:
    Connessione ...
    Errore. Connessione fallita.
    perché rneg non accetta l'aggiornamento?
    mi potete aiutare come risolvere questo problema
    grazie [/ QUOTE]
    Hello friend
    you have reolve problem not comunicate rneg with Martek?
    have info?
  4. #34
    May 2020
    Quote Originally Posted by Epap View Post
    Hello
    Many people as me in France have a specific trouble with the RNEG 1 (harman Beker) unit and some others have also this trouble with the RNEG2 (Magneti Marelli): these units are working well but reboot at regular intervals (every 30 mn for mine)
    I can understand that the trouble comes from a eeprom being corrupted (why?... no idea as I am just a normal driver)
    Repair consists probably in re writing the eeprom after clearing it (I am not sure) but costs a lot (600 € through Citroen network and that is unacceptable for just flashing an eeprom)
    Does anybody know wether using the Reanimate Your RNEG procedure found on the update firmware files would solve the reboot trouble?
    Thanks for your suggestions or now how
    hi, did you ever find a solution to the regular reboots?
  5. #35
    Jan 2019
    Quote Originally Posted by biguolot View Post
    Hello, I have a problem following the update of the firmware R50.3 which did not go through. I performed the manipulation to reanimate my rneg, but I can’t send the file "install_rnegd.ifs" by ZModem in Tera Term. In Tera Term I have this in loop :
    IPL: RNEG (6426.C1/0), 300 MHz
    [ver.10325A, built 2010-08-13 10:35:16 1931854]
    CS0: NOR
    boot img #0 from NOR [FPGA missing]... --- loaded 4907 KB in 649 ms [3552 => 7743 K/sec]
    *** jumping to c0200bc0 ...
    Startup: PL_qnx_startup-atlas2_07241A, built 2007/06/11_14-47-38_UTC
    Board: 00006426.000000c1
    RAM: 124 MB
    FLASH: 64 MB @0x10000000
    cpu_clock=300000000, dsp_clock=200000000, sys_clck=100000000, io_clock=100000000
    Dcache: 512x32 WB
    Icache: 512x32
    arm926 rev 4 300MHz
    System page at phys:c0017000 user:fc404000 kern:fc404000
    Starting next program at vfd0203a8
    Unknown type 255
    Shutdown[0,0] S/C/F=11/1/11 C/D=fd005fd0/fd05c060 state(c0)= now lock
    [0]PID-TID=1-4? P/T FL=00019001/05020000 "proc/boot/procnto-instr"
    armle context[fd06694c]:
    0000: 00000011 0000000a 00000064 00010000 fd0905dc fd54ccf8 0000ffff 00000000
    0020: fd0014c8 00000010 fd059488 fd552f24 fc423000 fd552eb4 fd024160 fd001834
    0040: 6000001f
    instruction[fd001834]:
    03 20 f5 e7 01 30 d5 e5 03 64 92 e1 c0 ff ff 1a 01 00 a0 e3 c0 76 00 eb 00 70
    stack[fd552eb4]:
    0000: 00000000 6f72702f 6f622f63 7000746f 6e636f72 692d6f74 7274736e 00000000
    0020: 00000007 fd05bff8 00000000 00000000 00000000 00000000 00000000 fd049f00
    0040: 00000000 00000000 00000000 00000000 fd05a0d0 fd54e050 fd553008 00000000
    0060: 00000000 fd552f50 fd552f28 fd04b6d4 fd0014f8 fd553008 fd54e050 fd553008
    getdipclose
    Can someone help me? Thank you in advance, everyone.
    Hi.
    Because this manual is wrong
  6. #36
    May 2020
    hello friend what brand is it? magneti marelli? You have to remove the sd card and format it or put a blank and if you want I will give you a repair file, which is done through the usb port
  7. #37
    Usa
    my main problem is the 2nd step : Make a reset on the USB to TTL holding the ALT+B ... can't manage to make it !! my USB To TTL don't have any reset button !! or am i completly wrong !!!
  8. #38
    CARAUDIO's Avatar
    May 2016
    Svp le brochage
  9. #39
    Jan 2022
    Hello
    i have problem with my rneg
    I want to restore the old original software and here are the questions:
    - how to connect the radio to a laptop?
    - during the recovery, the radio is to be connected to the installation in the car and to do everything on the engine running?
    - which files should be uploaded to the radio?
    I have done an update of the Peugeot 508 in my Citroen C5 X7 software by mistake and therefore the wheel on the steering wheel does not work and it does not have all the functions available on the on-board computer display (turning off the automatic handbrake)
    I am asking for tips and possibly an answer whether this method gives the possibility of restoring the old software.
  10. #40
    Jan 2022
    Nothing? Pleas help me, where plug rx,tx and gnd?
    On picture is diferent like in posts.
    Somebody write 5,5,10... Someone else 5,5,1 or 5,4,1... I try today 5,5,1 and nothing...
    Please take me this pinouts
  11. #41
    hello,
    someone does it successfully ?
    l ll try to reanimate a rneg to
    in this vidéo he connect the rneg + display+ bsi on the bench
    https://www.youtube.com/watch?v=jgdHFlXQu5A
  12. #42
    Nov 2010
    Quote Originally Posted by talel66 View Post
    problem solved
    How did you solved this problem?
  13. #43
    Jul 2022
    Hi to all
    is this software/hardware only intended to revive dead telematics or can it be adjusted somehow? I'm talking about powering the antennas when, when powering both branches (AM/FM1 -FM2), it tells me that the AM/FM1 branch has no power, although both are enabled and the current goes there. It happened to me with two radios even with the cable antenna disconnected
  14. #44
    Jul 2023
    i need the pin rneg with the pc schema please
    many thanks
