Results 1 to 15 of 48
Hybrid View
    number7hd's Avatar
    Dec 2013
    I found it .... if someone need it - here You go...
    If my solution helped You - do not forget to THANKS !!!
  2. The Following 22 Users Say Thank You to number7hd For This Useful Post:
    adjee (15th February, 2019), axl (13th November, 2018), Col19 (22nd December, 2021), Epap (17th February, 2019), freeman2014 (12th September, 2019), g485 (28th May, 2018), glk96000 (8th November, 2019), gsmflasch (25th July, 2022), ilen (15th February, 2025), ilkovelichkov (13th May, 2021), juned2 (12th September, 2019), laki23 (19th July, 2022), mexanico1971 (20th July, 2023), michael 28 (7th January, 2018), norishor (16th February, 2021), PetShakal (4th December, 2022), ruemzaigc (28th February, 2024), sikib (10th November, 2018), sozeri (10th February, 2018), swissdriver (30th May, 2020), Weld hammadi (19th October, 2020), xdamdamx (2nd January, 2019)
  3. #2
    Mar 2010
    SAN RAFAEL MZA.
    hello friend has more information with this procedure. What soft do you use and so on? or who has that kind of information?
    Dec 2009
    Quote Originally Posted by number7hd View Post
    i have martech box 3 , i connect with rneg but i have this problem
    when i clic on emergency start i have this message:
    Connecting...
    Error. Connection failed.
    why the rneg does not accept the update ?
    can you help me how to resolv this problem
    Dec 2009
    problem solved
  6. The Following User Says Thank You to talel66 For This Useful Post:
    her (4th November, 2022)
  7. #5
    Nov 2010
    Quote Originally Posted by talel66 View Post
    problem solved
    How did you solved this problem?
  8. #6
    Oct 2015
    Default rneg reanemate
    [QUOTE = talel66; 3535192] ho martech box 3, mi collego con rneg ma ho questo problema
    quando clicco all'avvio di emergenza ho questo messaggio:
    Connessione ...
    Errore. Connessione fallita.
    perché rneg non accetta l'aggiornamento?
    mi potete aiutare come risolvere questo problema
    grazie [/ QUOTE]
    Hello friend
    you have reolve problem not comunicate rneg with Martek?
    have info?
  9. #7
    CARAUDIO's Avatar
    May 2016
    Svp le brochage
