Results 1 to 3 of 3
    Fec001's Avatar
    Default Opel Movano EDC17C42 CC problem
    Hi!
    I made tuning and DPF off for this car some month ago. Customer called me back, he realized the cruise control is not working. He is not sure if it worked well before the modification. I R/W ECU with K-tag, checked all options with diag. The cruise control option is detected in ECU coding, all releated buttons works ok, brake pedal switch and cluth switch are ok too.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Wrong dpf solution. Write ori and check if cruise control works
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Oct 2017
    it happens when u mod inj maps for cruise, taht is why when u do ddpf off it mods that map so it stops working. its not directly DPF related!
  4. The Following User Says Thank You to autoSP For This Useful Post:
    Fec001 (30th October, 2017)
