Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: Marelli mjd6f3
  1. #16
    Oct 2016
    I’m going crazy I use 6 hours and 3 different connectors I try with wires and can’t connect
    What I’m doing wrong
  2. #17
    Oct 2016
    Uh I’m an idiot I managed to work after 6 hours and it’s was just like I try for the first time.
  3. #18
    Oct 2016
    Default I got it
    Can someone remap this for more power I'm not really the best at it
  4. #19
    Aug 2014
    try this
    you have pass in PM
  5. The Following User Says Thank You to lsdlsd88 For This Useful Post:
    nikte (31st October, 2017)
  6. #20
    Aug 2014
    clear PM folder @nikte
  7. #21
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Hello
    It is an easy ecu with galetto , i was solder cables directly to ecu without adapter... you must be carefully with checksum correction...
  8. #22
    Oct 2016
    Default Marelli mjd6f3
    I run in to problem
    Car won’t start its start for second and cut down
    I write full bdm backup and still won’t start
    I read ecu and dumps are the same like first read
  9. #23
    Oct 2016
    hm now read have some difference at end
    did i burn this ecu?
    No errors in autocom diagnostics i can read ecu with obd and bdm without problems
  10. #24
    Oct 2016
    I noticed to at my first read eeprom status was 0 and 1 and now I see eeprom status 1 and 1
  11. #25
    Oct 2016
    MPC and Flash are the same like first time read i think problem are in eeprom they are not the same from yesterday and today so its can be immo problem?
    Can this be rapired or immo off?
  12. #26
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    you can use hexCmp or someting like that to see exactly the differences.....
    (different VIN maybe?)
  13. #27
    Oct 2016
    Quote Originally Posted by Panathaole View Post
    To many differences seams like eeprom get corupt under reading or wtirtun flash chip it`s should not be but it its
