Galletto show this option *CAN
what it’s that mean: obd or bdm
Can someone help me with pinout and connections on fiat 500 ecu mjd6f3
i try the one I picture and I take a photo of my ecu
i try for 3 hour without success
please only tested solutions no copy paste I use DK and google for 2 hours and found many different pinout
any solution with galletto or bdm100
before you read you removed resistance from 0 ohm?
terminal / uhds by obd full r/w
FILE SERVICE
nikte (31st October, 2017)
yes a removed 0 ohm
sorry what are " terminal / uhds "
google it.
DSG TUNING
File Service
i Found pinout and to share one more time
Can be done remap on this ecu with bdm100 galletto or xprog?
BDM ......
This ecu have M58BW016 not MPC55XX
What to select in bdm options
'" live and learn........ if you wont ....you ain't "
_______ . ____ . __ . __ . _______ . __ __ __ ... ---
If my post was HELPFUL please push THANKS button
i connect like this and can`t get connected to ecu
i try with bdm100 ( pinout are not the same on bdm100 and fgtech )
i removed 0 OMH and add 12V to pin 50 and 23 and GND to pin 1
