Results 1 to 9 of 9
    Default volvo v50 1.6d edc16c34 DPF OFF problem
    I have buy DPF OFF file from http://www.dpfoffservice.com/.
    have reset dpf Counter With autocom and also try With launch 431 before Write New file.
    No fault engine lamp or dtc but stil in limp mode, "egine Power reduced wisit workshop" in Dashboard.
    something wrong With dpf off file?
    Your exaust presure sensor disconected? If yes conect.
    Additive module have dtc?
    Sep 2016
    your orginal file is crypted or bad, 511kb? flash must have 2mb
    FILE SERVICE
    waldi1979's Avatar
    Dec 2010
    Quote Originally Posted by Speedofix View Post
    This side resembles EcuSoftService (ATR).
    Their solutions worked wright on this VOLVO.
    I cant check your files because ORI file is corupted.
    Jul 2012
    It might work !!
    maybe the problem is that you have to disconnect temperature sensor, differential pressure sensor and disconnect additive pump!
    have try to disconnect all sensors not pump.
    "reduced engine Power wisit workshop" come in display before i start engine.
    no dtc read With skanner.
    Jul 2012
    many dtc have been eliminated .. this is the reason why no errors are being made ..
    the buck that yu you bought is not ok ask for help ..
    I have all the time got fault p6620 on glow relay. can that make limpmode `?
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Yes , that is your problem.
