Results 1 to 9 of 9
    soxten's Avatar
    Mar 2013
    Default How to write original map to flash file by SWIFTEC? Saab 9-3 1.9TID EDC16C39
    I have a ECU here as some tuner has make, Car is now very smoky...
    Need help to understand Swiftec and write original map to a flash BDM file.
    1: I did download original file from Swiftec database, only maps so it must be a OBD file(?)
    2: I have read ecu flash from car by BDM.
    Files are attached here in post.
    I have swiftec but I am NEW on this type of operation...
    Is it possible to write original maps as I have download to my BDM file by swiftec?
    (DPF is of in tuned file, but that is easy to fix by swiftec)
    Can any tuner help me to make me understand and help me?
    Next problem, in Swiftec... is it possible to have 2 files to compare in windows? (in Winols It is easy to do this by drag files in to window)
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Obd file you can flash only by obd!!
    Same with BDM file!!
    swiftec make Your Bdm file with No problem.
    Second : swifec solution doesnt work for edc16c9/39
    Files from swiftec you can also compare in Winols.. best clear view
    Wysłane z iPhone za pomocą Tapatalk
    DSG TUNING
    File Service
    soxten's Avatar
    Mar 2013
    Dont understand,
    Can I write swiftec orginal file by bdm to my ecu?
    What swiftec solution dont work?
    Skickat från min iPhone med Tapatalk
    maajkii's Avatar
    Mar 2017
    Quote Originally Posted by soxten View Post
    Dont understand,
    Swiftec download original obd file... so you can’t write this via bdm.
    Swiftec don’t work for Dpf edc16c39/9...
    DSG TUNING
    File Service
    soxten's Avatar
    Mar 2013
    Thx for help!
    Can you do dpf off on original obd file from swiftec befor i connect ecu over obd and program that file?
    maajkii's Avatar
    Mar 2017
    Good and working solution only on BDM file for edc16c39/9
    DSG TUNING
    File Service
    alonedark's Avatar
    Feb 2017
    bdm file is ok for write by obd too, the bdm file have the same maps that obd file , open two swiftech sw and open in one obd file in ohter one bdm file and you can see the maps
    Aug 2014
    guys, he is only asking if he can COPY the maps area from the OBD file (downloaded) to the BDM read (read from car).
    in winols it's a 2 min job, I would not bother to learn how to do that in swiftech. use the right software for the right job
  9. The Following 2 Users Say Thank You to lsdlsd88 For This Useful Post:
    maajkii (7th November, 2017), soxten (7th November, 2017)
  10. #9
    soxten's Avatar
    Mar 2013
    I did write original maps by Kess OBD to ecu. that work fine.
