Results 1 to 7 of 7
    Apr 2017
    Poland, Poznań
    Default KESS V2 "ATTENZIONE" - tokens
    I've got on my kess FW4.036 v2.08 "ATTENZIONE...". Probably tokens has expired, I've tried to fix it but solution which I've got is not working. Has anybody 100% working solution for reset tokens ?
    Autotuner user
    Kess/Ktag
    WinOLS
    Sep 2016
    buy orginal, this not have tokens
    FILE SERVICE
  3. The Following User Says Thank You to voltechcar For This Useful Post:
    maajkii (7th November, 2017)
    Apr 2017
    Poland, Poznań
    Well, as You can suppose, this answer is not what I expected.
    Autotuner user
    Kess/Ktag
    WinOLS
    Digital Under's Avatar
    Oct 2017
    ...insert in update folder, connect kess and run ksuite
    GM FORD DODGE
    tuning - deleting - immo
  6. The Following 3 Users Say Thank You to Digital Under For This Useful Post:
    alexauto12 (15th November, 2017), fzhut (8th November, 2017), SW Perfomance (10th November, 2017)
    Aug 2015
    I also had reset token problem, solved it by using new tf card
  8. The Following User Says Thank You to dtip For This Useful Post:
  9. #6
    Oct 2017
    ... good decision
    ...after 20 write - change SDcard
    GM FORD DODGE
  10. #7
    Aug 2015
    Quote Originally Posted by Digital Under View Post
    ... good decision
    I meant update kess with files copied on new SD card , not old, not just change SD card, i cant see your point?
