Results 1 to 2 of 2
    wissamshaat's Avatar
    Oct 2017
    france
    Default need help with edc16c36 renault master
    hello everyone
    i realy need help from someone profissional
    the problem that i have is that my master is a 2009 master with a 2.5 dci 120 hp engine
    the original engine is brocken so i changed it with another 2.5 dci
    when i changed the engine i puted back the original injectors with the coding
    but the problem is that the replacment engine is a 2006 engine 2.5dci with 115 hp
    so now i have problems with the engine like clacking sound and a dtc of rail pressure
    i changed the injector back to the replacment ones and the problem perssiste
    so now
    i need someone to modify the dump for this ecu to work well with this engine
    so i want a 115 horse power instead of 120 and to change the rail pressure to be okay with the engine
    thank you verry much
    Oct 2017
    france
    the old engine had a edc15c3 ecu and i dont have it
    any help pleas?
