Results 1 to 4 of 4
    Default CAPTIVA DPF PROBLEM
    Hello captiva with deleted dpf and tuning, no original file, the driver does not shut down after 2 days unload the battery after disconnecting the main relay ok, you can see if dpf is well removed thanks
  2. The Following User Says Thank You to janusz21 For This Useful Post:
    mcday (1st June, 2018)
  3. #2
    ECU 0281015176 96892357
    Jul 2012
    Quote Originally Posted by janusz21 View Post
    your problem is the file you posted ..
    bad tuning and bad fap off 90% dtc off no error will be reported in case of a problem
    look for the original file and reset the ecu and then you can do a new job
  5. The Following User Says Thank You to mario38 For This Useful Post:
    janusz21 (10th November, 2017)
  6. #4
    Sep 2016
    sps, 5 minutes flash and orginal file or Databank Alientech.
    FILE SERVICE
  7. The Following User Says Thank You to voltechcar For This Useful Post:
