Results 1 to 3 of 3
    digi men's Avatar
    Nov 2013
    EU
    Default Hi, can someone check this DPF OFF P3008 2.0HDI
    I have here a bought DPF OFF, car is not in limp mode, but on dash is triangle and alert engine fault , but no dtc in ecu, we try resset all, and try disconect sensors, when they ar disconected, car is in limp, can someone help to check wat culd be wrong or make right ?
    Thanks in advance for anny help
    Stop worrying about what can go wrong, and get excited about what can go right.
    PRESS THANKS IF YOU LIKE MY POST AND IT HELPED YOU
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    EGR not fully mapped out so airflow higher than expected, sound like they played with egr when they did dpf off
  3. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    digi men (10th November, 2017)
    digi men's Avatar
    Nov 2013
    EU
    hi, thanks for the check , i have say i need only dpf off, can someone make the egr back maybe ? and let dpf off
