Results 1 to 9 of 9
    Sep 2010
    Default Hyundai SantaFe 2.2CRDI EDC16C39 DPFoff
    Hi, please, help me with DPFoff on Hyundai Santafe with automatic gearbox and with ECU EDC16C39.
    In ECU are these DTCs:
    P2002
    P1405
    thanks for help
    Try and give report
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    dpf off and dtc off chks is ok hit thanks and push reputtation button
    Sep 2010
    Hi, thanks for help. The solution is the same and generated by the DPF remover 2017. I tried this but car still has limp mode. I look at swiftec page and there is info about switch solution but for automatic gearbox is necessary to rea full backup by BDM. So for automatic gearbox is switch solution or not? thanks for help
    Oct 2017
    is switch but in different address, u need BDm read. also remember switch solution on these works only if all your sensors are ok and connected
    Sep 2010
    Quote Originally Posted by autoSP View Post
    I have BDM read! is it possible to make it?
    Sep 2010
    nobody have solution for this car?
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    contact AEM.....
    DSG TUNING
    File Service
    Jul 2011
    try this solution.
    DPF PRESSURE AND TEMPERATURE SENSORS CAN BE DISCONNECTED, LSU SENSORE DISCONNECTED.
    PASS.PM
  10. The Following 2 Users Say Thank You to draganelektricar For This Useful Post:
    konq100 (12th November, 2017), vopi (12th November, 2017)
