Thx, i'll try
Thx, i'll try
Has anyone managed to install BarryAllen on a dm600 clone?
I wma facing problem in setting up DM 600 PVR with Barry allen. I installed Gemeini. But there is no option ofr downloaind the CCam Mgcamd etc. How can we do that?
gemini images have removed all cam installs from image ! along time ago !
try mounting a different image or look in the relevant section for manual install of plugins
Hi, new on this forum. i know this is a very old thread but hope anyone could answer? Just wondering about the versions of the images that one install in Barry Allen when BA is installed on a DM600PVR , should they ONLY be Enigma 2 or could they also be Enigma 1? Thanx in advance :-)
The DM600 is an Enigma1 variety receiver so would need to use E1 images
Sure I know DM600 is "Enigma1" but from what I understand the "Barry Allen" plug-in is a emulator making it possible to run E2 images on a E1 box? Most BA packages are named "enigma2-plugin-extensions-barryallen_xxxx something, something" So I just installed it on a DM600 running Gemini V 4.70 and just wanna know 100% before I continue if I should use E1 or E2 images or then, if it at all matters? Maybe I got the wrong impression about it being an emulator?
apparently there is a PCD V9.0 enigma2 image for the DM600 from around 3 years ago which was classed as experimental, From reading around it crashed more times than it worked.
Barry allen is not so much an emulator its to use other images in Multiboot so you install Gemini 4.70 and BA and then try other images but from experience i have never seen BA actually manage to run an Enigma2 image on an Enigma 1 receiver.
I could be wrong
