Results 1 to 14 of 14
    Oct 2014
    Default correct checksum edc15m
    hi all!
    could somone please help me with this cheksum? i read eeproms and made the modification, but i hace no way to correct the checksum now.
    thanks a lot!
    Jan 2017
    Modena (italy)
    wich tool are you use for read the engine ecu?
    Oct 2014
    i desolder eproms and read with minipro
    Jan 2017
    Modena (italy)
    i can try to resolve your problem, but i'm not shure to good result.
    Jan 2017
    Modena (italy)
    i'm sorry, but winols don't correct the chks?
    Oct 2014
    yes mine neather
    Jan 2017
    Modena (italy)
    ok but if you do not write at least the eu identifiers, i'm struggling to figure out which ECU to do the chks
    Oct 2014
    we need winols 1.5
    Jan 2017
    Modena (italy)
    wich ecu is? hardware and software id? without the information nothing is done
    Oct 2014
    edc15m 028100050
    As you say, winols 1.5 corrects checksum in that ecu without problems.
    Oct 2014
    hi queroseno! problem is a donīt have winols 1.5 and is not possible to run it on win 10
  13. #13
    Aug 2014
    your file is a bad read, check your reader for good connections on the flash chip.
    here is a good read. you will see with this file checksum corrector works.
    http://www.digital-kaos.co.uk/forums...sum-corrector)
  14. The Following User Says Thank You to lsdlsd88 For This Useful Post:
    ivanrojo (13th November, 2017)
  15. #14
    Oct 2014
    maybe I choose a wrong eeprom for reading, chip is an amd but without number, i choose amd 29f010b maybe is other different
