Results 1 to 5 of 5
    May 2017
    Default BMW S1000RR ECU replace
    Is it possible to buy a used ECU and pair it with another BMW S1000RR?
    My plan is the following:
    I have ISTA+ and Rheingold to program a 'new' or empty ecu to a specific vehicle. Is it possible to reset or virginise a used ECU and then pair it as if it was 'new'?
    On the internet i found some stuff mentioning that if you are able to read the ECU by the BDM ports, and then rewrite all the VIN instances with FF or 0, the BMW software recognises the ECU as a new one?
    Is this correct?
    Dec 2012
    uk
    buy used ecu and rewrite bdm. must works
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    if you have old ecu from that srr you can make a full bdm read and write in new ecu.but other way you need to extract isn noumber and make virgin to pair with bike.
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
    May 2017
    Unfortunately, the old ECU is not functioning anymore after a bike crash.
    I have bought a used ECU without keys from ebay.
    @aem,
    How could i virgin it after extracting ISN number? I have loads of BMW tools from my work.
    Sep 2017
    Could not save anything from the old one? if you want I can leave the used ECU with your VIN ready to code key
    upload the files
