Results 1 to 15 of 18
    hayk57's Avatar
    Default Disable Glow Plug Monitoring Ford EDC16C34
    Can anyone please help me to disable glow plug monitoring on Ford Focus EDC16C34
    Car is in limp mode
    Thanks in advance
    Best regards
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    Quote Originally Posted by hayk57 View Post
    Car is in limp mode
    Thanks in advance
    Best regards
    yes that would be a nice one , I am also struggling with this issue from time to time , it is sad that a car run in limp mode because of a faulty glow plug , WTF? how did they think
    Sent from my HUAWEI Y560-L01 using Tapatalk
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
    Car is in limp mode
    Thanks in advance
    Best regards
    HI, sending pass in PM!
    I did not touch dtc, let me know if needed too!
    Regards!
    No Links In Signature Please !!
  4. The Following User Says Thank You to chiptunerkft For This Useful Post:
    hayk57 (13th November, 2017)
    Andrei2015's Avatar
    Oct 2015
    Default glow monitoring off
    here you have it m8
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
  6. The Following User Says Thank You to Andrei2015 For This Useful Post:
    johak's Avatar
    this is to have a choice
    if you use it please report
  8. The Following User Says Thank You to johak For This Useful Post:
  9. #6
    hayk57's Avatar
    Thanks guys I will try them and report which one worked for me
  10. #7
    Andrei2015's Avatar
    Oct 2015
    I had done same sw number before so 100% will work
  11. The Following User Says Thank You to Andrei2015 For This Useful Post:
    konq100 (13th November, 2017)
  12. #8
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    good choice to delete a limp that tells you you have a fuse blow or a bad relay on plugs.when cold weather come you will crank untill sun goes down and car will not start.
    or maybe you all live in africa
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  13. The Following 2 Users Say Thank You to aem For This Useful Post:
    Ignasvw (13th November, 2017), teamtuner (13th November, 2017)
  14. #9
    Andrei2015's Avatar
    Oct 2015
    Quote Originally Posted by aem View Post
    It is called "Post glow injection quantity threshold", do your homework before you write/speak next time )
  15. The Following User Says Thank You to Andrei2015 For This Useful Post:
    biela (17th February, 2022)
  16. #10
    aem's Avatar
    Jun 2014
    no matter how you call it.is limp mode.and is a bull shit to delete glow plug control monitoring.expecialy in your country and in your town BT where winter is colder.mr T
    FILE SERVICE
    Genuine WinOLS user
  17. The Following 2 Users Say Thank You to aem For This Useful Post:
    maajkii (14th November, 2017), teamtuner (14th November, 2017)
  18. #11
    Andrei2015's Avatar
    Oct 2015
    no matter how you call it.is limp mode.and is a bull shit to delete glow plug control monitoring.expecialy in your country where winter is colder....so better do your homework if you wanna repair cars ...do not cheat customers if you want to make money.
    better open your genuine WinOLS and search for that map and maybe you will understand. engine protections maps in case of error are stock, check it by yourself: curve for for engine speed limitation in case of system errors (as limitation torque) and torque limtation value in case of system error.
    Also open winols again, load any edc16 damos and search for Post glow injection quantity threshold in other cars and hopefully this will end this conversation
  19. #12
    aem's Avatar
    Jun 2014
    i know what are you talking about....but anyway i didn t talking about you that mod files.....i talking about that members who need to do this shit glow monitoring off on cars.like you see mr T i say ''maybe you all live in africa''.....but sometimes ......you forget about years of friendship.........LIKE YOU SEE i mod post after i realize who you are....
    if you wanna talk with users in damos words is your bussines.nobody will understand what are you talking about.
    conv closed!!!
    FILE SERVICE
    Genuine WinOLS user
  20. The Following 2 Users Say Thank You to aem For This Useful Post:
    bobolin4o (14th November, 2017), teamtuner (14th November, 2017)
  21. #13
    Spain
    Hi all,
    I´m really bouried about monitoring deleting , dtc´s and so on , cars must be repaired to get best performance and economy.
    In the case in this post... if you have any problem related to glow plugs and make the magic trick of delete monitoring, what you will get in return are clogged dpf/fap, any faults in temp sensors, fans, glow plugs, etc will not allow dpf regenerations, so before delete ecu strategies do a proer diagnostic season and repair de problem.
    Regards.
  22. The Following User Says Thank You to jnoroeste For This Useful Post:
  23. #14
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    why conv closed ?...is funny...why need glow plug control monitoring ?...use the spray for start engine... ...is better than see DTC on your diag...or dash blinks...
    we reppair cars with simple click-clack...what tf ...
    and...who the fux is T ????
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  24. The Following User Says Thank You to teamtuner For This Useful Post:
  25. #15
    Andrei2015's Avatar
    Oct 2015
    Quote Originally Posted by jnoroeste View Post
    Hi all,
    Regards.
    You don't understand, there were no dtcs deleted and monitoring of glows or relay are active. only limp mode for this function is moded. If you check in bmw or mercedes edc16 damos, they all have "Post glow injection quantity threshold" but in this case IQ is 100mg. Problem is that over night there are a lot of mechanics and tuners. Good luck
  26. The Following User Says Thank You to Andrei2015 For This Useful Post:
    voltechcar (14th November, 2017)
