EGR DPF OFF
if helped don't forget thank and rep
EGR DPF OFF
KILL_THE_IMMO (16th November, 2017)
Swiftec make this ECU fine.
You have trouble with preheating system.
Antipolution on display is equal to Check Engine light... It simply tells you, that there is some fault in the ECU...
A fault regard turbo pressure signal Incorect can trigger the antipoluton fault message. Also, this error can run the car in limp mode.
your DPF + EGR + DTC OFF
Pass in PM after push thank + reputation
