Results 1 to 4 of 4
Thread: edc1cp46 dtc
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default edc1cp46 dtc
    Can someone help with p2016dtc. Car is Mb glk 2013 edc17cp46 automatic. I tried manualy without damos, but no luck. found dtc, found dtc path table, but cant understand why its not working. Dtc table lenght 319 or smth.. but dtc patch seems different value. I that dtc path in that place 100% in this ecu, but i dont know why its not working. i attached the file. Regards
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Oct 2017
    test this methode for dtc off
  3. The Following User Says Thank You to DeSSeD For This Useful Post:
    Ignasvw (17th November, 2017)
    johak's Avatar
    this should work
  5. The Following User Says Thank You to johak For This Useful Post:
  6. #4
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Lol, Johak, i just saw that 2016 fault has 2 places in fault table, i touched first, you touched second and it works... Dessed you touch different place in dtc path and you touched other places, so i think you made flaps off. both guys regards for work. GJ
