    dd1's Avatar
    Aug 2014
    Default 2003 mercedes benz CL500 215 chassis, EIS.
    HELLO everyone. my cl500 might have a eis problem. when inserting the key will not turn or start. i read the key and all is ok with the key. scanned it with the DAS doesnt display a fault code and will not see the key. i had purchase another new key, chrome from the deal still wont recognise the key, in the datastream. i used to heat up the eis and it would start the car but now no luck. it will not turn the ignition. how can i fix this? is it something that needs to be replaced? i hope not the eis. maybe someone can guide me with this to repair the problem. thnx again
    workshop
    chek with star actual value
    i think EWM problem
  3. The Following User Says Thank You to mercis For This Useful Post:
    gokhanusta (18th November, 2017)
    dd1's Avatar
    Aug 2014
    Hi. DAS shows -- for the key value. And I had purchased a new key from the dealer. The same thing
    Shmortz's Avatar
    in the middle of nowhere
    see in actual values, EIS must see key is inserted or not, then must be recognised...
    dd1's Avatar
    Aug 2014
    hi, it wont see the key, the old or the dealer key.
    dd1's Avatar
    Aug 2014
    i should add that i can not even access the eis with the vvdi2 mb. DAS can read it ok. whats the vvdi2 connection pinout for the mbz cl500? the blue wire connects to what pin on the obd2 connector
