If not helps, change the camshaft position sensor.
Hello ;
I am facing hot start probleme with my golf V ; when the car is cold or i remove the coolant sensor the car start without probleme.
but when it is hot it make time to start.
I try to fix the startup map with replacing the zero value but always not starting.
can any one help please.
I attached my dump.
Autotuner user
Kess/Ktag
WinOLS
Anyway hotstart fix. It's 90ps, You want mod ?
Autotuner user
Kess/Ktag
WinOLS
Thanks for the reply fzhut.
Its 105. I change the camshaft position sensor. But always same probleme
Write down my hotstart fix and check
Autotuner user
Kess/Ktag
WinOLS
before i write it down i open with winols ; i noticed that i have do some fix as you for 9x9 map.
or is there anything else you have done? if yes ill try ; if no just tell me if not dangerous to write many time the ecu.
thank you
Fix the same way ? Nothing more than 9x9 map. No problem to write it many times - in every case. I've written EDC17C06 tricore BMW 14 times
Autotuner user
Kess/Ktag
WinOLS
laplace1050 (18th November, 2017)
try..pass sent pm
Hello
This is your file, pass in PM
Thanks a lot ; i l'll try and report.
