Results 1 to 4 of 4
    Oct 2017
    Default 2016 F150 DASH THRU OBD
    Hello you guys I'm working with a 2016 F-150 xlt with a 4" screen I have a DSP3 and it only give me the option up to 2015 F150. When I try to save the mileage thru OBD with the 2015 F150 selection it says "km read function not available program directly" or something along those lines and then it gives me the option to write km I don't wanna mess it up so my question is Has anyone used DSP3 to program a 2016 F150 WITH the 2015 F150 option to successfully adjust km thru obd? If not then what is the proper way to do this cluster? I tried searching but I can't find any info on a 2016 with dsp3. thank you before hands
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    contact your rep , but just in case whenever you see that just enter new and press ok
    Reading is fundamental, asking is easy............................
    or leave it b and walk away!
    Oct 2017
    Great advice thanks! It worked perfect
