Results 1 to 9 of 9
    Jan 2016
    Default 2J74Y Monitor ROM
    Hi Guys.
    I've read in Motorola 2J74Y datasheet that this mcu doesnt "use" monitor rom but when I see dumps read by ETL there is monitor rom present. Could someone here with ETL experience tell me: to do full copy of 2j74y monitor rom is necessary ? I have comfort module with 2J74Y foulty and did copy with X-prog ori and it doesnt work. When I heat original mcu all works fine. Rgs.
    Dec 2010
    As far as i remember you can read all 3 memories (flash,eeprom,rom), but you write only the flash and eeprom.
    Do you have a good source for the 2j74y ? I found some of them had defect with the eeprom.
    Jan 2016
    I have good source for 2j74y. I use them for Jaeger clusters with Carprog. But now I have to do full copy of mcu and I am courious if X-prog can do it as good as ETL ??
    So what for is monitor rom in this mcu's when I cant copy this sector to new one ??
    3inferno3's Avatar
    Nov 2014
    Europe
    Quote Originally Posted by amigokola View Post
    here you have my 2j74y solution...flash and eep. very good read.. pic with my sesion..
    Jan 2016
    Carprog cant read good whole flash from 2j74y. You have some custom made tool ??
    3inferno3's Avatar
    Nov 2014
    Europe
    You wrong.. flash and eep. do very vell... add 13.5v power and try in circuit or desolder like me on pic...and you will do this...
    Jan 2016
    Here is flash read with Carprog and Xprog and tell me that Carprog read it good...
    Eeprom is the same.
    Jan 2016
    Somebody could explain to me what for is Monitor Rom in 2J74Y and can Xprog do full copy of this mcu like ETL ??
    Jul 2014
    Sofia
    You don't need to copy/clone monitor ROM. It is not used by the MCU in normal operating mode as in dash, ezs or whatever
