Results 1 to 7 of 7
Thread: Rav4 dpf off
    Oct 2017
    Default Rav4 dpf off
    I need rav4 d-cat dpf off.
    May 2014
    There is wery simple sollution.
    Emulate temp sensors. Use 2 diodes (1N4004) for each senson and resistor 1k ohm for 5th injector. Diodes connect in series, cathode connect with brown cable.
    Disconnect rear wavy line from diferential pressure sensor and clog it.
    Thats all...
    Oct 2017
    Thanks, will work on it
    Oct 2017
    Thank you so much rafalgt. I made the emulator and the car runs fine. No smoke and no fault codes. Thanks alot.
    Sep 2020
    Quote Originally Posted by rafalgt View Post
    Thats all...
    Hi, can I ask you if you know the trick for a 2.5 D4D Toyota Hilux ? Engine code is 2kd Ftv and I’m facing this limp mode. I already « de-biscuited » my exhaust but not sure about the resistors location
    Envoyé de mon iPhone en utilisant Tapatalk
    Jan 2022
    Im trying to do this on a Lexus IS220d (same engine)... The "wavy" hoose from diferenttial sensor is the line that reads pressure before or after dpf? And my temp sensors have no brown wires, there is other way of indentify positive amd negative wires? Thanks
    Jun 2018
    Hi . 1000 ohm is correct value? and watts ?
