Results 1 to 5 of 5
Thread: NOt booting up
    Jun 2008
    Default NOt booting up
    I have a sagem dbox2 when booting up the dbox it gets stuck at the loading kernal screen on the lcd screen. I have tried to re-flash the box with ifa but no luck as ifa is unable to flash it since it just keeps booting up normally. Does anyone have a solution for this problem?
    Thanks in advance.
    Jun 2008
    Quote Originally Posted by mo.p View Post
    Thanks in advance.
    lfa is the answer...u switching on box only after loading img in ifa and pressing ok?
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Make sure firewall is turned off when using IFA. It's best if you assign an ip address to your ethernet card rather than using DHCP.
    You may have to try a couple of times before it starts to flash.
    Jun 2008
    Yes i have flashed the box the way i normally flash it i flashed 2 other box's and its only this box that i am having a problem with. All firewall is off and ii cant change the ip as i cant even get the box to boot properly it gets stuck on the sportser image loading kernal.
    Jun 2008
    try this version, never failed for me....
    IFA Image Flashing Assistant TuT.rar
    setup_dboxifa_en.rar
    cheers
