Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Norway
    Default Cheap tool to read/write saab psg16 ecus?
    Anyone know of a cheap tool to read/wirte this ecus with?
    BR
    KP
    you can doit with op-com
    tech-2 write only or opticant
    Norway
    I know, but thats not cheap tools
    BR
    KP
    There is no cheap tool for PSG16
    Yes with Tech2,but if you make modification,Tech2 don't make the checksumm :-( and EVC is not ready yet with this ols
    Quote Originally Posted by daviee View Post
    Of course EVC has checksum for PSG16
    Quote Originally Posted by exe123 View Post
    Yes but not for Tech2 file :-(
    Belfast, NI
    Heard of something called nasrasoft but no experience, may have an ori if anyone wants to look? Its like a vp edc16 file!
    Above sea-level
    Can it also be done with op-com?
    (posted by eobd)
    Which (handheld, obd...) tech2 tools can flash the psg16?
    Link?
    Bishop c4's Avatar
    chess board
    it seems that the Tech2 read and write PSG16.
    but the bad news are you need to modify the file and find a way to loaded with Tech 2.
    Tech2 reads nothing!
    You can read id from car with tech-2 after you have to get flash data from opel server via Tis or GDS.
    This data can be read from card, modified and then you can write it to card.
    No cheap job and if you **** the ecu you are ****ed.
  13. #13
    Moon
    it's not such a big deal ...
    tech2 on car => SPS
    go to TIS and copy flash in memory card
    copy card content in PC
    split the 32 mb file and get 1mb file
    modify and calculate checksum
    integrate the 1mb file in 32mb file (compare the dumps to be OK)
    copy 32mb file in card and program with tech2
    Problem solved!
  14. #14
    Quote Originally Posted by bazare View Post
    tech2 on car => SPS
    Problem solved!
    Which program do I need to convert 32mb file to 1mb?
  15. #15
    DK Veteran danielm's Avatar
    HEX edtor
    BR
