Results 1 to 4 of 4
    Jun 2012
    Default Need egr off Ford Transit 2.4 TDCi
    Hi need egr off in Ford Transit 2.4, 2007, ecu Visteon nr 6C11-12B684-AB and delete dtc P0403, P0404, P1402, P1409 related with egr. Need disconnect egr plug.
  2. The Following User Says Thank You to autoelek For This Useful Post:
    peppiniaddruzzu (27th September, 2020)
  3. #2
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Try this. pass pm. Use rep button
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  4. The Following User Says Thank You to Ignasvw For This Useful Post:
  5. #3
    Jun 2012
    This file is made by egr remover and not ok. I tried before and still P0403 and after disconnect egr plug also P1402. Bad solution.
  6. #4
    Dec 2011
    TRY THIS NO PASS USE PEP BOUTTON
  7. The Following 2 Users Say Thank You to imoturbo For This Useful Post:
    eeprom241 (28th October, 2021), vitorponte (18th November, 2019)
