audio problem
  • bullseye
    • 8
    audio problem
    hi i have a zgemma star h1 with openatv 5.0 can someone kindly point me in the right direction to a image that will fix this problem thanks
  • joe516
    • 1000
    Andy Mc Open ATV-6.1 2.0
    https://www.dropbox.com/sh/ucc3q7mxkwdiue2/AABFS4RnX6LPIPP_mopBmC_Ua?dl=0
    I have on my zgemma star h1 m8
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
    • bullseye
      • 8
      All sorted thank you very much
      • makster1978
        • 118
        hi will this work on the zgemma lc
        • rockfordbass
          • Nov 2010
          • 5
          how did you sort audio issue
          • P&D
            • May 2010
            • 2686
            Flash the box & Install a new image
              hi,running openatv 5.3 on a h2h,if i flash a new image will i lose the unmentionables from it or will it just need bouquets and region installing again, really got no idea
              • digicon
                • 8261
                You have a couple of options either do a full backup of your current image which will save everything and then if you hit a snag can just reflash the same image, Do a partial backup which will backup the afore mentioned part (partial backups may not work with newer images due to kernel changes such as on OpenATV 6.1/6.2)
                Lastly FTP with say filezilla to your box locate /usr/keys folder and backup whats contained inside there to your laptop/pc
                  2 days with no au
