Results 1 to 13 of 13
    Jul 2016
    USA
    Default 03 Silverado Cluster just Odometer blank
    2003 Silverado odometer - information display in the cluster was dim than it completely went blank. Everything else works except this display. How can this be repaired ?
    Jan 2014
    Michigan State USA
    Quote Originally Posted by borshch View Post
    Check if any fuse control the cluster
    Check at the back of the cluster power ground too via plug
  3. The Following User Says Thank You to KALNAJJAR01 For This Useful Post:
    borshch (26th November, 2017)
    ascrap2003's Avatar
    Sep 2016
    Texas
    Search the forum Silverado or GMT800 you'll find what you need!
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
  5. The Following User Says Thank You to ascrap2003 For This Useful Post:
  6. #4
    Jul 2016
    USA
    Quote Originally Posted by ascrap2003 View Post
    Searched.
    found that mosfet or transformer might be bad. But which one ?
    And idisplay might not be getting power. But what needs to be fixed to get power to display ?
    Also found that most just replaced the entire cluster. And that's what I usually do, but other guys know how to fix this instead of replacing the whole cluster.
  7. #5
    ascrap2003's Avatar
    Sep 2016
    Texas
    Searched.
    Mosfet I believe is only for the 07-13 Trucks but I maybe wrong as usual, 03-06 you should have 6 or 7 small smd resistors just above and/or left of speedo stepper, did you reflow/solder those?
  8. #6
    mecjp's Avatar
    Oct 2013
    other world
    as ascrap2003 said check this resistor at left back of board and you will see some sign of black overheat on soldering point, just resolder that and try to power up on bench! if u not sure post a picture! good luck.
    sharing is the key of success
  9. #7
    Jul 2016
    USA
    those are only for the shift indicator display (PRND321). But I need to fix the other display the one that shows odometer, trip, messages.
  10. #8
    Jul 2016
    USA
    Quote Originally Posted by mecjp View Post
    The back of the board doesn’t have any resistors or any components.
    Ill post photos soon
  11. #9
    clusters's Avatar
    Mar 2015
    Canada
    For starters, power up the bad one and a good one and do voltage tests to compare, like we all did when learning. Read up on MOSFETs, specifically n-channel, yes they are used in the early ones as well. The transformers rarely fail, but your problem is most likely in the same area which is the DC to AC converter circuit.
    Please DO NOT PM me asking for help.
    Post in the forum, that is what it is here for.
  12. The Following 2 Users Say Thank You to clusters For This Useful Post:
    ascrap2003 (30th November, 2017), borshch (29th November, 2017)
  13. #10
    ascrap2003's Avatar
    Sep 2016
    Texas
    [QUOTE=clusters;3156335]For starters, power up the bad one and a good one and do voltage tests to compare, like we all did when learning. Read up on MOSFETs, specifically n
    None of which i've done yet besides mosfet testing NPN
    heres another hint NPN = Negative Postive Negative
    and for the noobs and slower guys like myself heres a easy
    way to understand circuit components.
    We'll use plumbing and water flow to understand
    Resistor is pretty much like a flow regulator/larger pipe into a smaller one
    Diode is basicly a check valve
    Mosfet is a type of Transistor which in turn is another kind of diode think of a tee with a ball valve and check valve on each of 2 outlets
  14. The Following User Says Thank You to ascrap2003 For This Useful Post:
  15. #11
    mecjp's Avatar
    Oct 2013
    other world
    check this video at 13 minutes, i make mistake is on the other side hope this will help https://youtu.be/vStMcCHZuRM
  16. The Following 2 Users Say Thank You to mecjp For This Useful Post:
    borshch (29th November, 2017), MileageAudit5 (11th November, 2019)
  17. #12
    Jul 2016
    USA
    In video only shows repair of prnd display not of Odometer - info display
  18. #13
    rrador's Avatar
    Feb 2011
    Tamo daleko
    resoldering resistors should fix odometer display also. Have done many and it worked. Just did one few days ago.
    Never had one of these that needed anything else other than resolder resistors. Also keep in mind once you remove needles you'll probably break some stepper motors.
    When I open these I always replace all stepers and bulbs...
  19. The Following User Says Thank You to rrador For This Useful Post:
    borshch (6th December, 2017)
